Genesis Lar
Posted on - 11/23/2011
Hello Guys.
I am a Linux user and I am using Fedora 13.
When doing updates this message always pops up.
Is it ok to continue this one?
Anyways I don’t encounter any problem about this message, but I just want to know why this program needs to modify also?
Error:
Additional confirmation required
To install this file, additional software also has to be modified.
The following software also needs to be installed
Citrix Receiver for Linux
ICAClient-11.100-1(i386)
Additional confirmation required- Citrix Receiver for Linux
This is not an error. It only informs you that after you finished updating the programs on your computer, the system wants you to install Citrix Receiver for Linux prior to the updates that were finished.
Since you are not having any problems with your system even if you did not install Citrix Receiver for Linux, you may or may not install it.
This information only appeared because you made some updates on your operating system that required this component application to be installed. You can still click Continue but every time you do updates on your computer this message will always appear.
If you no longer wish to see this message appear after updating your system, check the Do not show this again option before clicking Continue.
