Additional information about linksys log viewer.
Hi techyv,
Additional information about linksys log viewer. I got a Linksys router which I bought two days ago, and the set up was successfully done. I can access the wireless internet connection without any problem and errors, but I would like to know how does a linksys log viewer works. Tell me more the advantage of having one.
Hoping for your help. Thanks.
Best Answer by Baker Martin
Answered By 0 points N/A #185829
Hi there,
It is said that a Log viewer is a reliable application that shows any kind of log in the real time without reopening the file again and again. It also displays lots of log files in the same viewer at a time.
For more information on how to use the Linksys Log Viewer, just click this site, https://isc.sans.edu/index_cached.html
And in using this Linksys Log Viewer Application, you need to change the file sizes of the incoming and the outgoing files to as large as you can.
Answered By 15 points N/A #185831
You can do this with your browser.
  • Open your preferred browser (IE, Firefox, Safari, Google Chrome) and type instead of URL '192.168.1.1'
  • Select 'Security' tab
  • Under it select 'View Log' option
And you will be able to see log files if you have set up your router to create log.
If you haven't check out the user guide from Linksys website it will guide you on how to set up logging and other log related functions.
