Adds to the First Row only in VB
Hello there guys!
I've been currently making a Visual Basic program.
In my Order Slip Entry part, every time I add up new details on the Flex Grid,
It only adds up on the first row only.
What would be the cause to this?
Answered By 5 points N/A #99260
Hi Xavier,
I think you missed just a line of code or two for this problem. Remember that Flex Grid operates in row and column coordinates. When you add data to your flex grid you need to adjust the (column, row) values.
For example you have a flex grid with 5 columns. You may want to start to insert data at row 1 provided that row 0 are for column headers. Your first row of data could be like:
==Empno | Empname | Position | Address | Salary
row 1-> 1111  | xavier          | SA          | 15b. St.C|9999
row 2-> 2222  | hereddia    | SA          | Cor#2, B | 8888
To insert your data on the second row you need to code like:
FlexGrid.TextMatrix(2,0) = "2222"
FlexGrid.TextMatrix(2,1) = "heredia"
FlexGrid.TextMatrix(2,2) = "SA"
FlexGrid.TextMatrix(2,3) = "Cor#2,B"
FlexGrid.TextMatrix(2,4) = 8888
For shorter code you need to do it in a loop increasing the value of row so that Flex Grid inserts it in the next row.
I hope it helps.
