Jay Skarbos
20 points
Posted on - 05/12/2012
I downloaded the latest (Rel. 1.4.2) ADF7023 Evaluation Kit Software (.zip) from Analog Devices FTP site.
I tried to install the software in 3 different XP computers but still failed in doing so.
Every time I go through the tedious installation process, this error appears on my screen:
Microsoft Visual C++ Runtime Library
Runtime Error!
This application has requested the Runtime to terminate it in an unusual way
Please contact the application's support team for more information.
Please help me troubleshoot this error.
Can someone send me steps to manage the error?
ADF7023 Evaluation Kit Software error on installation
I was unable to access the site where this program can be downloaded. The site encountered an internal server error. If you have already tried installing this program on 3 different computers that were all running on Windows XP, try checking the application’s system requirements. Probably, the version you acquired and is trying to install doesn’t support Windows XP or if it supports it, it requires a different Service Pack or a different version of the operating system, either 32-bit or 64-bit.
Since I can’t reach the site, try visiting again the web site where you downloaded the program. Check if the page has its system specifications. This is important when installing an application.
Please check the program requirements before installing it on any computer also check that this program is 32 bit windows supported or 64 bit window supported and make sure you are using proper way to install the program. Check that this program is compatible with current OS you are trying to run and make sure that you have a valid copy of program.
Smith Thompson
