Adjust pic size on msn
I am using MSN messenger on my PC for communicating with others. But unfortunately, when I want to upload any picture, I cannot adjust picture size on MSN. Is there any solution for this problem? Please help me with your solution.
Thank
Best Answer by Rayan Pattrick
Answered By 0 points N/A #198045
Thank you very much for your question. By using simple software you can solve the problem easily. The name of the software is "Stuffplug". This will help you to upload any type of image.
Answered By 0 points N/A #198046
Thanks for posting your question. The problem you are experiencing is not so unusual, it happens. The solution therefore is to use a program called VarieDrop and you can be obtained from the following:
http://www.vieas.com/en/soft.html#VarieDrop.
These programs will help you much during the resizing in the MSN.
Hope this helps.
Regards
Answered By 10 points N/A #198047
Hello Dorethadhoward,
You need to use a program called IrfanView, which is free for use and is easy to download and install.
Use the following link to download it,
https://fileforum.betanews.com/detail/IrfanView/967963863/1
Download its Plugin,
https://fileforum.betanews.com/detail/IrfanView-PlugIns/1099412658/1
Install this program use it to customize images on MSN.
Use the following links to learn how to install and customize images,
http://johnbokma.com/messenger/make-display-pictures.html
http://www.somewhere-in-time.net/tutorial/irfanview/
I hope this solves your problem.
Thanks,
Answered By 0 points N/A #139572
Hello, while there are programs out there to help you with this issue, a simple solution would be to open up a drawing program on your pc, such as Paint or Microsoft Office picture viewer.  I am using Microsoft Office picture viewer for this example.
  • Open photo in Microsoft Office picture viewer:
  • Click Picture on top toolbar
  • Click Resize
  • You can either click crop and resize to 96x96pixels, which is the standard size for MSN pictures;
  • Or if you have a very large file click resize to make your picture smaller, then crop the picture to 96 x 96pixels.
Hop this helps.
