Hi Experts,
I am having a Lenovo desktop.
I want to adjust settings on Lenovo s100 bios reset.
Actually I need to reset bios of Lenovo pc.
I will be able to reset bios if anyone tell me to access bios.
Which key should be pressed when pc is booting.
Nekoda Monty
Adjust settings on lenovo s100 bios reset ?
Hi Nekoda monty,
For accessing the Bios setting in Lenovo Desktop you can press F1 key and then press enter.
After entering Bios you can reset the Bios System and save the setting.
It may help you.
Thanks!
Hi there user:
Restart your Lenovo PC. Press the F1 right away when the think-pad logo appears.
Follow what you are prompted to press, and then a message will appear saying ‘to interrupt normal start-up’.
You may now select ‘Start set-up utility’ to open the BIOS set-up menu.
Follow the instructions prompted.
Download the PDF guide
Thanks for asking.
Best regards,
