Adjusting the Dlink Home router
I am using a dlink router at home and I want to know how to adjust it and is it possible to adjust it always?
OK,
At first you need to plug one end of the Ethernet cable into the DSL modem. Then Plug other end into “WAN” port. Then you need to connect wired computers to any of the other Ethernet ports on the router using another Ethernet cable. Then write "http://192.168.0.1"
into the address bar, & press “Enter” button. Then Use “Admin” as the username and leave the password blank when the login screen appears.Click “OK”. After that you will get Dlink Configuration screen. If you want to Change your administrative password, click on the “Tools” tab and choose the “Admin” button. Enter a new password under the “Administrator” heading. Re-enter it again & apply it. Go to https://www.dlink.com.ph/how-to-setup-wpa-psk-wpa2-psk-for-dir-300/ for a detailed instruction. You can also see this video
Notifications
