Administrative Rights when downloading .exe files
Recently, I cannot download any .exe files on my computer. I am thinking that maybe there is an issue with the Administration access. But I am the only user and the only Administrator of my computer. I did not receive any updates from Microsoft. I am thinking that maybe it was because Microsoft has finally ends their support on Windows XP but I am receiving error that says I am not the Administrator of my computer. So I am certain that this is the possible cause why I cannot download .exe files. When opening in Firefox, I am receiving error stating: “C:Documents and SettingsMyNameDesktopApplication.exe could not be saved, because you cannot change the contents of that folder. Change the folder properties and try again, or try saving in a different location.”
At first, I am guessing that this is just an issue with the folder so I decided to moved the folder to other location and try every possible solutions that I can do. I also checked if the problem is just with my browser, so I used other browser such as Internet Explorer to no luck. I tried running the downloaded application but it says, I do not have the user right access and I could not download to the specified file path. Does anyone have a solution for this? Is this an issue with the Administrator rights?
