Ado problem on Windows 7 missing OCX using visual basic 6.0
Hi I am trying to find out on how to retrieve the missing msadodc.ocx in Windows 7 I am using visual basic 6.0 thank you in advance. 😀
MSADODC.OCX just acts like a translator in your system, it plays an important role in maintaining the stability of our computers and the integrity of the system
it is missing from you device because there is another software or cleaner program that may be either remove it or disable it's service so i advice you to check your programs properly before something like that happen again
you can easily get this missing system dll by navigate into this URL
https://www.dll-download-system.com/docman/ocx-files/msadodc.ocx/details.html
and download it
RegardsÂ
The file msadodc.ocx is very important for the stability and security of your system. However, it seems that some software on your computer is either removing it or disabling it. Therefore, you have to perform a thorough check of your system and then copy the file from https://www.ocxdump.com/download-ocx-files_new.php/ocxfiles/M/MSADODC.OCX/6.00.81714/download.html.
