Adobe Acrobat 9 Standard Batch Processing
Is it possible to use a batch process in adobe acrobat 9 standard? I need to automate as follows: Alt DXD, return x 2, Alt FA, [pause for filename entry], return, Ctrl W. until all records have been named.
Hi!
Sadly batch processing for Adobe Acrobat is only available in their Professional version. The standard version is aimed towards users of any skill level to read and create PDF files, which left the batch processing along with the higher features to the professional and extended versions. To avail the batch processing feature, you can upgrade your standard to professional and follow this simple tutorial.
You can also check out https://acrobatusers.com/ for other batch processing techniques you can make for your future documents.
It’s real easy and will surely lessen your work time!
Best regards,
Lloyd Feld
