Adobe Acrobat Data and Time error
I am using Adobe Acrobat now I want to set date and time in one column but when I try to set date and times then I receive below error. Please tell me adobe acrobat support such type of functionality or not.
File check in failed. The server said:
“Invalid date/time value
A date/time field contains invalid data. Please check the value and try again.”
Please ensure you have completed all required properties with the correct information and try again.
OK
