Lonnie
Posted on - 12/10/2011
Hi everyone,
Until recently I haven’t used Adobe Acrobat. This is a question from a newbie,and every suggestion is more than welcome.
In Adobe acrobat I wanted to have time or date inserted. On the internet I have read more suggestions but none of them was successful.
Please help by step by step if possible. OS: Windows XP SP2
Thank you
Lonnie
Adobe Acrobat
File check in failed. The server said:
“Invalid data/time value
A date/time field contains invalid data. Please check the value and try again.”
Please ensure you have completed all required properties with the correct information and try again.
OK
Adobe Acrobat File check in failed Invalid data/time value
It is a bug from adobe which when you create a column types like Date, Person or Group and Lookup. If your PDF document have a column of date and time and you try to save it to a SharePoint, you will encounter this error message from Adobe. Adobe is the one who must fix this one; it is a bug from them. So for your to fix this one you must contact adobe customer support and tell them about the error, and what you should do, I know they can help you. The only solution for that for a mean while is not to use date and time column.
Hi Lonnie,
It was occurred by free trial version used from your computer. You have to register or update apps and reinstall it. Registered certificate and serial is most important. So put the right way of using.
Another step, if you have register the software then check if it's legit or illegal. If it's illegal try to remove it completely and download again from a trusted website.
Ask for your properties are caused by virus or low disk space. Make enough space to use it. You can delete the unnecessary file or program from your computer by XP disk.
And after install from new update your Adobe from related website. This may increase your value.
