Adobe Acrobat Invalid data/time value
Hey guys,
I have done some back up of files into external USB HDD.
Now whenever I try to start any of files with PDF extension I got an error message.
What should I do with this?
Anti virus program is not reporting that files are infected. OS Windows XP
Thank you
Lorie
Adobe Acrobat
File check in failed. The server said:
“Invalid data/time value
A date/time field contains invalid data. Please check the value and try again.”
Please ensure you have completed all required properties with the correct information and try again.
OK
