I have been using adobe acrobat reader for a while to open pdf files. Recently it has not been working properly. For few days I am unable to use acrobat reader to open pdf files for which I have to depend on some other reader. I really want this problem to be solved because there are other functions available in acrobat reader which I do not get in other readers.
Jovan Clayton
Adobe acrobat reader cannot open PDF files
Hey Jovan!
As you told that your Adobe Acrobat Reader stopped working, and it was working before. It seems that your Adobe Acrobat reader got corrupted and you need to fix it by repairing your Adobe Acrobat Reader.
You can fix it by following these steps:
1. Open Adobe Acrobat Reader.
2. Go to help on the toolbar (on the top of the window) and select "Repair Adobe Reader Installation".
It will fix all the errors and will automatically fix the problem.
You can also do it by these steps:
1. Go to control panel.
2. Open Add Remove Programs.
3. Find Adobe Acrobat Reader
4. Click on "change" and follow the instruction.
It will also fix your Adobe.
Thanks
points
There are many reason you can get this problem. You can also get this error message too while you will try to open PDF files.
So to get rid this problem you can visit this:
Adobe Reader Error cannot open some PDF files
Visit this site and enjoy!
