waq345
Posted on - 08/25/2011
Hello!
I have a problem while installing adobe acrobat reader. I receive a message , "Error 1935. An error occurred during installation of assembly ". Due to this error installation is interrupted and all processes are rolled back.
Following are specifications of my computer ,
Pentium IV -3.0 GHz
RAM 512 MB
Windows XP (SP-1)
Woods
Adobe Acrobat Reader Installation Error
Well there is no problem with your computer hardware specifications as they the requirements to install the Adobe reader. It is best to download the fresh copy of Adobe reader from the internet (at http://get.adobe.com/reader/otherversions/ ). Alternatively, install it from a CD. I hope this works for you. Thanks.
The error here is most likely due to a component of the installer that is not functioning – that might be due to a corrupted file. Adobe Acrobat Reader is freeware and can be downloaded and installed freely. Your image shows that you are using Windows XP and your computer’s meets the minimum specifications for installation of Adobe Acrobat Reader.
If you continue on receiving this error message it could be that your download is corrupt. Repeat the download directly from their site: http://www.adobe.com/.
