Adobe Acrobat Setup Error has encountered
The following problem occurs when I try to download ‘Java’ and click on setup to install but the issue displayed as an error. How can I fix this error message? First, I tried to remove it and reinstall the program but the error still remains. Do you have any idea to fix this problem? I would be grateful to you for any assistance.
Adobe Acrobat XI – Setup
Error 1723. There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor. Action ISSetupFilesExtract, entry: SFStartupEx, library: C:UsersDarren-1AppDataLocalTempMSI2ED.tmp
