Adobe After Effect Rendering problem!!
I am using Adobe after effect CS 3 I made a 50 Sec project, it was a music video and I had used many 3D objects. But every time I tried to render the file in AVI file format, after rendering a few frames it stops!
Can anyone tell me what's the problem ?
Answered By 25 points N/A #126984
Really hard experience Mr. RexDS, I am sure you will get out of it by doing this:
This most sure is not takings with the RAM “Try to extend it over 3 GB”, and somewhat of the effects booming due to the thing footage being tainted or in the way they are functional and stack. You should try a simple give with the photo prime and then transform on those pre-rendered collection. If possible you should determine a "stout" dissever particular as TIFF for the pre-render, not amazing as uneasy as PNG.
If after doing the above problem still persists then visit this address for more solutions:
http://generalspecialist.com/troubleshooting-after-effects-all-versions/
