Adobe after effects error loading the projects
Hi there,
After I saved a project from After Effects this error appeared when save was done. I clicked OK and I was expecting for a log which didn’t appear. Should I be worried about this message ? Why is generating a crash log ?
Thank you !
After Effects
A copy of your project was saved at: /Users/mc/Desktop/Mr. Sad Sack’s Problematical Project_1.aep.
Generating crash log, which may take a few minutes.
Answered By 590495 points N/A #180409
I guess Adobe After Effects crashed after saving the file. Restart the program then try loading the file again located in the indicated path “/users/mc/desktop/Mr. Sad Sack’s Problematical Project_1.aep”. In case the application crashed again after restarting it, restart the computer then open Adobe After Effects again. See if it runs.
If it doesn’t work, open Finder then navigate to the Applications folder and then trash or drag the Adobe After Effects app to the trash. This uninstalls the application. After that, run its installer to install it back on your computer and see if it works. If the problem continues, download the update from Adobe After Effects for Macintosh depending on your version.
Available updates are for Adobe After Effects 3.1, 4.0, 4.1, 4.1.1, 5.5, 5.5.1, 6.0, 6.5.1, 7.0, 12.0.1, 12.1, 12.2, 12.2.1, CS3, CS4, CS5, CS5.5, and CS6.
