Adobe after effects error with ratio addition
Posted on - 08/09/2014
While I was working with Adobe Effects this error message zero denominator appeared. If I press the OK button nothing happens and I can continue the work. The problem is that I don’t think that this error appears without a reason. Why this error appears ? What this error means ?
Thank you !
After Effects
After Effects error: zero denominator in ratio addition.
