Adobe application error during the updates
Hi experts,
Application in use is the error when I want to uninstall the Adobe applications. I closed all the open application from Adobe Suite and it still appears. Is there another way to check for the open apps ? How can I uninstall the Adobe Suite ?
Regards !
Applications in use…
Please shutdown the following applications and click retry or click cancel to quite.
Answered By 0 points N/A #180254
You can use of revo uninstaller.
You can get it from here : www.revouninstaller.com
Run it and choose the application that you want to remove then choose the Forced Uninstall then Advanced. Follow instruction to remove your software completely.
( Note : Remember to remove the registry path that included the software folder. The Revo uninstall make a restore point before starting so do no worry about changing in your registry )
