Adobe asked for updates so I have accepted to download and install. During the install this error appeared and messed up my Adobe products. Is there a solution to fix this error ? Why I have this error?
Thanks !
Updates
Some updates failed to install.
The following updates were unable to install. If you wish to install these updates, please fix the problems below and retry.
Adobe Photoshop Elements 9.0.3 Update
Patch cannot be applied. Please contact product support. Error Code: U44M1P2003
Contact Customer Support for further assistance
QUIT
Adobe Application Manager failing installing the updates
Check again if the failed update really damaged the application. If Adobe Application Manager is open, close it and then start Adobe Photoshop Elements since this is the application you wished to update. Check if the program starts normally and successfully. Usually, when installing an update and it fails, the original installation of the program is untouched. The program can still be opened without a problem even after a failed update.
But in your case, if Adobe Photoshop Elements can no longer start because of the failed update, simply reinstall the application and it will be back to normal. Uninstall Adobe Photoshop Elements then click Start, All Programs, Accessories, System Tools, and then click Disk Cleanup. Select drive C and then click OK. Check “Temporary files” then click OK. Restart your computer when it is finished and then install Adobe Photoshop Elements back.
If you wish to update the program, you can do it from within the program instead of using Adobe Application Manager to avoid any problem such as this. To update, start Adobe Photoshop Elements then click Help and then Updates. See image.
