Adobe Audition Could Not Find A Supported Audio Device. Please Check Your Device Settings. What Should Be Done?
Lehman Ahmed 0 points N/APosted on - 02/12/2017
I have a software Adobe audition where I am mixing some auditory files. An error is occurring that adobe audition could not find a supported audio device. Please check your device settings. What should I do?
This trouble can be acknowledged in dissimilar types.
Either your ‘Operating System’ is not well-suited with your installer.
Or
You need one more system of the auditory in the array to start the installer. Make sure to download that is well-matched to your Windows. Now, follow the ladder to download and install.
If you have Adobe Audition but it throws an error that it cannot find a supported audio device, the program is referring to your sound card. In this case, check if you have a sound card installed on your computer. If you have a sound card and it is already installed on your computer, try reinstalling the driver. Right-click “My Computer” and select “Properties”.
Select “Hardware” tab and click “Device Manager”. On the next screen, expand “Sound, video and game controllers”. Right-click your sound card and select “Uninstall”. Restart your computer and install the sound card driver again.
Uninstall sound card
Once your sound card has been reinstalled, try running Adobe Audition again and see if it works. If the problem continues, visit the Adobe website and check the system requirements of Adobe Audition. Your sound card is probably not supported because it lacks a certain feature required by the program. This means you need to replace your sound card with a new one that is supported by the program.
Before buying a new sound card, consult the system specifications of Adobe Audition and verify what kind of sound card is required.
1....
