I am trying to install Adobe Creative Suite 4 or a CS4 application, the installation fails and the following error appears. What should I do now? Any idea
Error 1320. Error writing to file C:Config.Msi7dc400.rbf. Verify that you have access to that directory.
Adobe Creative Suite 4 or a CS4 application installation fails
Hello, At the time of installing Adobe CS4,mainly two kinds of error reports Error:1303 and Error 1310 occurs. Sometimes this error occurs when we try to install this kind of application at a time running other application. So first disable all other running application in your system and then try to install it. Sometimes this problem occurs due to your directory settings for this the error message are shown. Rename this selecting directory and run this application. For more details you can visit https://helpx.adobe.com/creative-suite/kb/error-1310-error-writing-file.html
Hope this works.
