lesliewestt
Posted on - 09/05/2011
System errors during launch I am using Adobe Creative Suite 4 when I open this for working then I receive below error this problem appear only at mac operating system first I use Window XP it works for me, but when I install mac os then it is not working.
Can any one tell me its solution? Please tell me its complete detail.
The application Bridge CS4 has unexpectedly quit.
A crash report has been generated. To provide us with the best chance of fixing this problem, please select Continue to add a detailed description that includes the steps required to reproduce the crash.
Adobe will use this crash report to help find a future solution to this problem.
Cancel Continue
Adobe Creative Suite 4 System errors during launch
The solutions of your problem regarding on the Adobe Creative Suite 4 application that might not running in MAC OS then you have to try this details on how to resolve your problem:
Step 1. Navigate to the product executable using Windows Explorer.
Example: Adobe Photoshop CS5 is located in /Program Files/Adobe/Adobe Photoshop CS5.
Right-click the product executable and choose Properties. On the executable files, Right-Click and Click Properties
Example: Right-click Photoshop CS5.exe and select Properties. You might notice that the executable files may not display the file extension .exe. Just ignore and proceed.
Click the Compatibility tab.
Under the Compatibility Mode, Click Setting and Privilege Level and Then Deselect any options. Just follow shown below.
Click OK.
Try to launch the Adobe Creative Suite 4 product again.
