Hello experts,
I just installed on my laptop Apple Snow Leopard and I have this error in Adobe CS 3. I read something on the Internet and I found out that this OS have some major problems with Adobe Suite like Flash, Illustrator, Fireworks, etc. Is this true ? Please help me to solve this error.
Thank you
Some characters could not be converted to outlines because an appropriate outline font is not available. These characters will disappear in the Flash Movie file. The characters that failed will look jagged if you choose Anti-Alias Text in the View menu.
Adobe cs 3 fails on apple snow leopard
I guess you really have a problem running Adobe Photoshop CS3 on your Mac OS X 10.6 Snow Leopard because the application is not compatible with your operating system. Adobe Photoshop CS3 only works on Mac OS X 10.4.8 Tiger until 10.5 Leopard while your operating system is one level higher.
If you want to use Adobe Photoshop CS3, you need to shift your operating system to Mac OS X 10.5 Leopard to support the application. But if downgrading your operating system is not an option for you, you probably need to shift to Adobe Photoshop CS5 because this version supports Mac OS X 10.5.7 Leopard until Mac OS X 10.6 Snow Leopard.
If you want a much higher version, you can try Adobe Photoshop CS6 which supports Mac OS X 10.6.8 Snow Leopard until 10.7 Lion.
