Adobe CS5 on Mac Operating System getting some trouble
I am running Adobe CS5 on my Mac Operating System but I am getting some trouble from last days. When I try to open Adobe Fireworks CS5 on Mac OS the program does not launch and the following error message displays on the screen. I can’t understand this issue. I have searched the solution from forums but could not get proper resolution. Any help would be greatly appreciated. Thanks in advance.
Fireworks cannot run
Fireworks cannot run. A parameter was incorrect
Answered By 5 points N/A #176056
Make sure you have the permission to edit folder contents.
a. Navigate to the /Library/Preferences folder using the Finder
b. Control click the Fireworks launcher in the directory and select Get Info
c. Under the Sharing & Permissions menu, select Details to display owner and group settings.
d. Click the lock icon and enter admin username and password as specified.
e. Give Read and Write permissions to your user credentials
f. Select Apply To Enclose Item and close the Get info window
g. Do the same process to other folders within the Preferences directory
h. Launch Fireworks
