Adobe cs6 xNormal Scripts/filters not showing up.
Hello Techyv's
I need help with some thing here. I installed xnormal after i installed cs6 and it didn't show up in my filters section so I uninstalled it and re installed it and its still not showing up.
So, my exact question is how do I get scripts to show up in the Photoshop script menu?Also how do I get the xnormal plugins to show up as well?
Thanks,
Edward Rand.
Answered By 30 points N/A #144152
Hello Rand,
To show up the scripts in the Photoshop script menu, you need to do few things:
At first close the Photoshop if it’s open. You have to copy the script to its ‘Scripts only’ folder in the Photoshop installation directory. On the Windows the path will be something like:
C:Programs FilesAdobePhotoshop CS6PresetScripts. And to get the xnormal plugins show up, just copy the 8BF file manually. The path will be like this: C:Program FilesAdobeAdobe Photoshop CS6 (64 Bit)Plug-insFilters. Hope this will help.
Good Luck.
