When I started to run the Adobe Dreamweaver CS4, an error message pops up saying
Microsoft Visual C++ runtime library: runtime error. Does anybody here know how to address this issue?
I am very frustrated right now. Attached is the screenshot of the error.
Any help would be appreciated.
Thanks!
Error:
Runtime error!
Program: …rogram FilesAdobeAdobe Dreamweaver CS4Dreamweaver.exe
This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information.
Adobe Dreamweaver CS4 Runtime Error pls help
Hy,
This type of problem occurs for the visual basic runtime error. If you give so many pressures or give multi command in your above Dreamweaver CS software then you may get this type of error instantly. It can happen in Macromedia Dreamweaver too. So if you give error command in your Dreamweaver software then it can give you instant error.
So I recommended you to use Above Dreamweaver portable version to keep safe from this type of error yourself. Your portable software will help you to keep your computer fast. There have no need to install this software in your hard drive. So it saves your CPU usage.
