ShannonE
Posted on - 10/04/2011
Hey, everyone! I need a little advice on Adobe Dreamweaver CS5!
I downloaded Adobe Dreamweaver CS5, because I want to create a website for smartphones. I cannot open the software. When I click to open it, I get an error message. I also have the trial version of Adobe Dreamweaver CS4, which gives me the same error message. Why am I getting this error?
Adobe Dreamweaver Error
 C:Program FilesAdobeAdobe Dreamweaver CS5Dreamweaver.exe
 The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line
Adobe Dreamweaver CS5 Error Message
This error occurs because of some missing file. Especially when there is some assembly missing in the winsys folder.
So you have to download this file from internet.
But we don’t know that which file is missing so I will give u some files, try downloading them one by one and your problem will be solved. Before installing these files make sure that you are logged in as an administrator.
Now try to download these files one by one and installing them on your computer.
a. Download details Microsoft Visual C++ 2005 Redistributable Package (x86)
b. Download details Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)
c. Download details Microsoft Visual C++ 2008 Redistributable Package (x86)
d. Download details Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)
e. Download details: Microsoft Visual C++ 2010 Redistributable Package (x86)
After installing all these try to update your copy of windows and your problem will be solved.
