Hi to all
I have recently installed the HTML editor software Adobe Dreamweaver on my system.
When I execute a program, it gives me the following error on my screen:
The error says:
While executing onLoad in XolDwExShutdown.html, the following
JavaScript error(s) occurred:
At line 383 of file “C:Program File (×86)AdobeAdobe Dreamweaver
CS5ConfigurationSharedXolDwExSharedXolDwExlsShared.js”:
XolDwExls is not defined
Can anyone please let me know why is this happening?
I have tried hard by all means to find the solution, but I could not.
If anyone can please tell me how to solve it, that'll be great.
Waiting to hear from you soon
Kindest regards
Ammelia
Adobe Dreamweaver JavaScript error at line 383
While using Dreamweaver, you may encounter some JavaScript errors such as the above problem.
That might happen when you lunch/close your Dreamweaver.
Sometimes users experience those errors while for example you are to access some codes on a PHP page and other.
Try to remove the WinFileCache-7A9586CB.dat file from the Dreamweaver configuration folder.
See below:
For Dreamweaver CS6: C:UsersYourUserNameAppDataRoamingAdobeDreamweaverCS6[language]Configuration
For CS5.5:
C:UsersYourUserNameAppDataRoamingAdobeDreamweaverCS5.5[language]Configuration
For CS5:
C:UsersYourUserNameAppDataRoamingAdobeDreamweaverCS5[language]Configuration
For CS4:
C:UsersYourUserNameAppDataRoamingAdobeDreamweaverCS4[language]Configuration
And then try to run it again.
hope it's helpful
