Adobe Dreamweaver for Linux ?
Can I run Adobe Dreamweaver in Linux? If so, what are the process on running it on Linux-based system?
Hello Yvonne S Gresham!
1. You need to install first WINE program via Ubuntu Software Center.
2. Download the Dreamweaver installer then right-click 'Open with' -> 'Wine Windows Program Loader'. Wait for a second and it will start installing on your computer.
Please note that not all Windows application will run on Linux Machine using Wine. You can also try different IDE’s Eclipse, Aptana Studio and Quanta.
Hi Yvonne S Gresham
There is a support to run windows applications in Linux. I personally go to this experience in past and learned some new things from there, there are 6 tools or packages which you can use on Linux to run windows applications
There are multiple cross platforms for Linux instead of Dreamweaver.
They both are fully visual and they have friendly user interface too.
Johnstoon Leen
