Adobe dreamweaver widget browser on iMac
Hi, I have downloaded and installed Adobe Dreamweaver widget browser on my iMac but whenever i try to sign in I receive an error message saying "Unable to load WSDL" and asks me to check my internet connection, which works fine.
Does anyone know how I can fix this?
I've tried restarting my PC and reinstalling the program but it didn't help.
Thanks
Best Answer by Randolph Brownlow
Answered By 35 points N/A #154250
Hi there,
If you are using any proxy, try to see if that is working or disable it. Otherwise you have to go to your default browser and delete all the ADOBE cookies, now all the widgets will be available. Also make sure your default browser accepts cookies.
Hope this helped,
Answered By 5 points N/A #154251
Hello Kevin
The WSDL loading error means that the URL may not be accessible from your browser.
Please make sure that you have a proper crossdomain.xml in the server. The crossdomain.xml should reside in your server's root directory.
Check the link I have provided you with in order to fix this issue. It will offer you another perspective on this issue.
Unable to load WSDL
I hope you will find this information useful.
Randolph
