Adobe Encore is not running
Hi Guys,
I have  an AMD Phenom Quad core with a nvidia 9800gtx running on windows & ultimate.
I have been trying to run my Adobe premiere CS5 but I get this error message:
Adobe Premiere Pro.exe – Entry Point Not Found.
The procedure entry point.
?FillWithOpaqueBlack@GF@@YA?AW4cudaError_enum@@AEBV?$shared_ptr@VDevice@GF@@@boost@@PEBXHUPixelFormat@dvd mediatypes@@HH@Z could not be located in the dynamic link library GPUFoundation.ddl.
It had no problems when I installed it.
Answered By 0 points N/A #123626
Entry Point Not Found error in Adobe Premier can be easily fixed. This may occur when your computer is not properly configured. Make sure you have configured the system properly.
Or
This might be occurs when some files that require to run the Adobe Premier Pro is missing. To fix that you can first try the repair option. You have to run Adobe Premier Pro set up file and do a repair. Or else reinstalls the software and try. Files can be missing due to the virus effects.
Or
You can use an error repair tool to fix your problem.
Visit the below site
https://www.dll-files.com/client/upgrade/
