I install Adobe Firework in my system after installing this software I give its key then my adobe Firework is working properly. Then after doing work few hours I close this program and turn of my system after few hours I again start my system and try to use this software but this error appears. I try to remove this error but I can’t remove it. Please tell me its solution.
Licensing for this product has stopped working.
You cannot use this product at this time. You must repair the problem by uninstalling and then reinstalling his product or contacting your IT administrator or Adobe customer support for help.
                                                           OK
Adobe Firework Licensing for this product has stopped working.
Hi peter, no doubt that you found an error here but my friend here this error shows clearly everything so there is no need to worry about. Here you solution comes and that is you can remove first all of your previous files of that software from your computer and make sure that those files are really deleted. Then you can download and install a new file for that flash and then run that new file. I hope it will help you to fix your problem.
Cheers.
Hi!
Adobe has a certain number of installations for every product. You may have installed your Adobe more than once or may have not deactivate it when you transfer your Adobe to another computer. Another issue may be that your license had expired or already invalid. You may again try to uninstall the product but try to deactivate it first by clicking on the Help tab to have a clean spot on your computer. Reinstall and if the problem persist, it is best to contact Adobe’s Customer Service and explain your dilemma. They can deactivate previously installed license so you reactivate your Adobe Fireworks.
