Adobe Fireworks CS6 Opening Error
While opening Adobe fireworks CS6 it refuses to run, and there is a popup menu saying “an internal error occurred.” The popup menu will not respond, and the task manager is used for closing fireworks. How to resolve this problem?
Answered By 5 points N/A #318144
Follow the following steps to overcome the problem –
1. You need to move the fonts from the ‘fonts’ folder to a temp folder that is created on your desktop.
2. Try and start fireworks. If firework starts normally, you can install the removed fonts to the font’s folder in small batches of 30 at a time. After every batch, you install launch fireworks and check if it starts regularly.
3. If it doesn’t starts regularly repeat step 2 with much smaller batches of 10 fonts at a time.
4. Repeat the above steps to isolate the fonts that prevent fireworks from launching.
