Adobe Flash 10.2 installer error
When I want to install Nero 11 in Windows 7 64-Bit Pc and Windows Vista 64-Bit Pc, the installation was failed because of an “Adobe Flash 10.2 installer” error.
Also,this could happen with any other item of the Nero 11 or the recent updates for Nero 10.
Please do something to solve it.
Adobe Flash Player 10.2 Installer
The installation encountered errors:
The version of Adobe Flash Player that you are trying to
install is not the most current version. Please visit the Player
Download Center to obtain the latest. most secure version
        QUIT
Thanks a lot.
Best Answer by Prodhan Felix
Answered By 5 points N/A #141431
Dear,
Adobe flash player is required for different graphical purposes on computer. In order to have a proper installation of adobe flash player you need to turn off internet browser. If any browser is running during installation of flash player then it will not install properly and error message will show. So turn off all browsers during installation of adobe flash player.
Thank You.
Answered By 0 points N/A #141432
First of all you must uninstall old flash player,
And reinstall the new one from www.adobe.com but you must select for the 64bit support .
And Nero 11 must support 64bit to.
Answered By 0 points N/A #141433
Hello Anna,
Follow the steps below and I hope your problem will be solved,
1. If you have any previous versions of Adobe Flash Player installed on your PC then first uninstall that.
2. Download the latest version of Adobe Flash Player for browsers like Mozilla Firefox or Google Chrome here, https://get.adobe.com/flashplayer/
If you use Internet Explorer then download the latest version of Adobe Flash Player here, https://get.adobe.com/flashplayer/
3. Then check that all of your browsers are closed or not. If any of the browsers are open the installation will fail. So, make sure your browsers are closed while installing Adobe Flash Player.
4. Install the latest version on your PC.
Hope you will not face any problems further.
Paul.
