Hi there!
The new Adobe Flash Player 11 does sound quite popular indeed.
Can anyone tell me what are the new features and specialties of this product of Adobe?
jk7861
Adobe Flash 11.1.111.10 related question
We already know  That  Adobe Flash Player is Used in Almost All of the web browsers. Its used for watching Videos, Animations,Flash & to Play games in the WEb browser.  The Latest version of The Flash Player by ADOBE is the Adobe Flash Player 11. Its Basic work is the same as its predecessors. But It  has All New Features as well.
Stage 3D accelerated Graphic Rendering : Explore a new architecture for high-performance 2D/3D GPU hardware accelerated graphics rendering by Adobe, which provides low-level Stage3D APIs for advanced rendering in apps and gives framework developers classes of interactive experiences.
Native 64-Bit Support: Flash Player can now take advantage of native support for 64-bit operating systems and 64-bit web browsers on Linux®, Mac OS, and Windows.
Enhanced Hingh-Resolution Bitmap: Enable the development of apps that use very large bitmaps. BitmapData objects are no longer limited to a maximum resolution of 16 megapixel's (16,777,215 pixels), and maximum bitmap width/height is no longer limited to 8,191 pixels.
Full Screen KeyBoard Input: Enable full screen mode with full support for all keyboard keys inside Flash Player. End users can allow content to receive keyboard input or chose to exit full screen mode.
Deliver Rich User Experience: Deliver more engaging user experiences with the Adobe® Flash® Player runtime through support for native 64-bit operating systems and browsers, accelerated graphics rendering, asynchronous bitmap decoding, high-resolution bitmap support, and more.
Currently, the latest version is Adobe Flash Player 21.0.0.242 which was released on May 12, 2016. On this date, Adobe released security updates and bug fixes for Adobe Flash Player and Adobe AIR. The following are the changes described in their changelog for Adobe Flash Player:
* Printing issues and truncation on https://www.techyv.com/ (4129993).
* Pepper only – fixed issues with custom Right click handling of flash player (4136373).
* Space metacharacter (s) is no longer including non-breaking spaces (xA0) (4137804).
For the Adobe AIR, the following issues were fixed:
* Microsoft Windows and iOS – IPA packaged on Windows machine cannot be submitted to the Apple App store. Error "This build is invalid" occurs in iTunes connect (4144943).
The latest version of Adobe Flash Player can be downloaded from Get Adobe Flash Player.
