Adobe Flash CS3, ActionScript 3.0 Error
I am having this very unusual error while importing the frame contents to a MovieClip. I copied this MovieClip from AS 2/ Flash 8 to Flash 9 but I got the error below:
Adobe Flash CS3
This feature is not supported by Flash Player 9, ActionScript 3.0. To use this feature, you must target Flash Player 9, ActionScript 3.0.
I am thinking of importing from AS 3 file if that will fix the problem. But I need your ideas. Thanks.
