Adobe Flash lite wii download
I was asked for Flash player when I was trying to play a video in my Wii.
Is there any way I can do Adobe Flash lite wii download?
Thanks in advance for your answer.
You cannot download Adobe Flash Player above 8. Because current Wii console doesn't support it. The only thing that you can do is wait and hope Wii system soon release an update with Adobe Flash Player 9 or beyond it.
Here is the solution to update Wii upto Adobe Flash 8. You just need to update your opera browser through Shop Channel. Just follow very simple steps to update it:
1. Click on Start Shopping option and then Wii Channels.
2. Scroll down to Internet Channel and on the left screen choose Download Browser Update option.
On successful updating your Adobe Flash Player 8 will be automatically get updated.
Hello Abraham,
You can download the flash player Lite for your Wii through the Wii shop channel. To get the Lite version all you have to do is change the Adobe flash (version 7) to Adobe Flash Lite (3.1).
This is basically the Adobe flash player version 8. To download the flash player please follow the simple steps:
1. From the Wii shop channel, press the start button to download the updated internet channel.
2. Also visit Adobe Official website for further information.
Notifications
