Adobe Flash Player 10 not successfully installed in Windows Vista
Does anyone here can help me fix an issue with an Adobe Flash Player 10?
I am trying to install that on my laptop which is running with Windows Vista. Every time it begins installing I always have an error message telling me that it cannot contact tracker and it appears when it is already at 12 % progress. And I’m playing Farmville, Cityville, and most common games in Facebook a lot and since I have no Flash Player installed I could not play anymore.
I am really looking forward that somebody can help me and I am very thankful if you can.
Answered By 5 points N/A #91226
It seems like you are trying to install the adobe flash player directly from the internet. Well, in that case you will need to make sure that your internet connection speed is strong enough. If you have some downloads going on, or you are playing online games then you will need to stop that a little bit so as to reduce bandwidth consumption and allow the flash player installation to complete successfully.
An alternative will be to just download the adobe flash player and install it manually on your computer. You can download it from the manufacturer's site, or any other trusted site like cnet downloads or majorgeerks.
Experttechyv
Answered By 590495 points N/A #314412
Adobe Flash Player 10 is way too old to be supported by flash-based games on Facebook. Also, if you are receiving errors when installing Flash Player from the Adobe website, you are probably downloading the web installer.
There should be no problem when using the web installer provided by Adobe on their website but if you have a slow internet connection, installing Flash Player using this option might be a little troublesome. To fix the problem, download the offline installer so you won’t have a problem installing it afterwards. To download the latest Flash Player, download the following:
The latest version at the moment is Adobe Flash Player 31.0.0.153.
