When I go for updating the “Adobe Flash player 11.r300”, it crashes and stops working giving me an error message as shown in the screenshot. What is the solution here?
“Adobe Flash Player 11.3 r300 has stopped working.
Windows can check online for a solution to the problem.
Check online for a solution and close the program
Close the program”
Hello Norman L Trent,
In many cases, the AdobeFlash Player crashes and stops working. You may face this problem because you opened the browser when you were trying to update it. When you open your browser, you cannot update the Adobe Flash Player to the latest version, so you must close your browser and then try to update it.
You can update the latest Adobe flash player in offline mode from the site below:
Adobe Flash player 11.7.700.128 Beta (For 32 Bit).
Adobe Flash player 11.3.300.257 (For 64 Bit).
Now enjoy it.
