A problem occurred with adobe player for blackberry storm. The adobe player of my blackberry storm mobile phone is not working, when I tried to run my Mozilla firefox it crashes and never let me view the webpage content. I really need to resolve this problem as soon as possible, kindly tell me on what to do. Thank you.
Adobe Flash Player for BlackBerry Storm is Not Working
If you are using an old version of the adobe flash player then you are bound to get such errors. Or the adobe flash player that you are using could be corrupted. You will therefore need to update the flash player to the latest version, or just remove it completely from your device and then install a new one.
Nicke
Hi Vannessa Onnoya,
Some blackberry user's encounter this problem and they usually reinstall it to fix the problem (I am not sure with your case). I prefer you to go to some forums in which they discuss about your concern. I have attached some example forums below for your reference:
Blackberry: My boyfriend's Storm came with Firefox.. but I want it too!
Blackberry Support Forums: Firefox Web Browser – Where to get it?
Hope that it would help you.
