Hello Tech people,
I got an odd error message while I am trying to preview the project in Adobe Flash Player. I do not understand where I went wrong literally. I get this error message often please guide me to rectify this problem. Enrich me with some ideas. Help please. Thanks in advance.
Adobe flash player Security
Adobe@ Flash Player has stopped a potentially unsafe operation. The following local application on your computer or network.
///Users/carloslu/Application Support/Adpve/Flash CSS.S/en_US/Cpnfiguration/MediaMind/JS/Files/AD/RES/12092012141751104_asser_RichManner1.swf?
points
Adobe Flash Player blocked unsafe operation
Flash is also a great media for exploiting viruses. In order to keep you safe, Flash has got a built-in security settings that will keep you safe.
The application you’re going to open contained unsecured content that might harm you greatly. This message is warning you only about the concern.
If you still want to open the content and trust it, you have to do it at your own risk. Do the followings:
Go to Start menu.
Type “flash player” in search bar >> hit “Enter”.
Open “Advanced” tab.
From “Developer Tools’ section, click “Trusted Location Settings…”
Click “Add…” from the bottom-left corner.
Now, add your file/folder to “Trusted Location” list.
Now, Flash Player will allow you open your content.
