I have an updated version of adobe flash player which I have updated so far each time an update is available. Recently it is unable to run files that it used to run.
Especially the YouTube files which I have to explore all most often. I am in some serious predicament and need someone to assist me in this problem.
Maverick Bozo.
Adobe flash player cannot run the youtube videos
I have the solutions that I have used for this kind of problem please clarify this thing on your Google chrome:
1. Check the plugins of your Google chrome if your flash is installed and check if it is enabled.
2. Try updating your flash plugin to the latest version that is available at adobe.com (download and install the flash).
3. Try updating your Google chrome to the latest version that is available on the site.
4. Make sure you’re antivirus or Google chrome browser does not block the flash or you have installed programs that block flash files from loading.
