I'm a longtime user of Mozilla Firefox but recently used Google Chrome Plus 10.1for a change. I'm having issues viewing embedded flash videos. The error is "Adobe Flash Player was blocked because it is out of date". I already updated the Flash Player version but still the same error. Are there any compatibility issues with Adobe Flash Player for Chrome Plus in Windows 8?
Adobe flash player for chrome plus blocked
Hello Dear,
If you are using Flash Player version 5 and update it to the latest version, then it will still not work like the latest version. This means that you have updated your old version, but it is blocked because the version is still old. I suggest you download and install the latest Flash Player.
You should try Flash Player 11. You can download it from this link.
http://www.adobe.com/support/flashplayer/debug_downloads.html
I hope this will help you.
If your browser says Flash Player is outdated then just update it. Download the following and install on your computer:
If this doesn’t work, you need to update your web browser to the latest. For Firefox, go to the Mozilla Firefox homepage and download the latest. For Chrome, go to the Google Chrome download page and get the latest version. This link downloads the standalone installer. For Opera, go to Opera for PC and download the version for your operating system.
With regards to the use of Adobe Flash Player, Adobe announced in July 2017 that they will be ending support for Flash Player by the end of 2020 and continued to encourage the use of open HTML5 standards in place of Flash. Microsoft announced in September 2019 that Flash will be completely removed from all web browsers on December 31, 2020 via Windows Update.
