giddeo
20 points
Posted on - 08/14/2011
One thing i am trying to understand that after some days passed, why my Adobe Flash Player is automatically corrupted. When i opened youtube.com the message appeared showing that you have need to reinstall adobe flash player. I have to reinstall adobe flash every time but what is the permanent solution of this. Why it so happens. Some one help this regard and tell me about the cause of this?
Adobe Flash Player is Corrupted after two days
Adobe Flash player issue mainly occurred because of registry errors. So you should clean your registry in daily basis. To clean your registry you can use Tune Up Utilities software or Ccleaner software, that help you to clean your registry errors & remove unwanted temp files.
To get this issue fixed you should uninstall adobe flash player completely from your PC & then download latest version of adobe flash player & install it manually & remember during installation you must close all your browser. One thing you must keep in mind try to update your browser with latest updates.
I hope it will solve your issues with adobe flash player.
Thank you.
Regads.
