Adobe Flash Player installation problem
My Adobe Flash Player was working fine the other day but now there's a pop up message telling me to install a most current version. I wanted to watch a video from You Tube using my Firefox browser, but it said that my Flash Player has crashed.
I tried to re-install Flash Player by clicking the link from the error message, but it seemed that nothing happened. I still had the same error.
If I uninstall Flash Player, can I uninstall from the Control Panel?
Install Adobe Flash Player
! The installation encountered errors:
The version of Adobe Flash Player that you are trying to install is not the most current version.
Please visit the Player Download Center to obtain the latest, most secure version.
Please help!
Can't watch You Tube!
Best Answer by Sharath Reddy
Answered By 590495 points N/A #83815
Yes, you can use the Control Panel to uninstall Adobe Flash Player from your computer. The most common cause why Adobe Flash Player crashes while playing an online video game, watching streaming videos or chatting is that the media you are accessing requires a recent or the latest version and the current version that is installed in your computer is kind of outdated.
There are online media that does not require your Adobe Flash Player to be updated. But it is best to update your version to the latest because there are lots of improvements in the latest release. You will be able to experience higher quality audio and facilitates smoother conversation flow in online chatting without using a headset.
Adobe Flash Player 10.3.183.10 is the latest release and can be downloaded in Adobe’s website: http://www.adobe.com/downloads.html.
Answered By 0 points N/A #83816
Try this site: www.filehippo.com
In the search bar type adobe flash player, enter, choose a adobe flash player you want to download (IE Or NON IE) after that you can see in the right was the latest version of adobe flash player and download it..
Thats all
