Hello All,
I am using Internet Explorer 8 in Windows XP and I am failing to watch You Tube videos. When I try to play You Tube video it says "You need Adobe Flash Player to watch this video". I downloaded Adobe Flash Player several times. But it’s not working. Please help me in this situation. Thanks in advance
Adobe Flash Player Needed when Playing YouTube Videos on IE 8
You have not mention the version of your internet explorer. I don’t know what version are you using, 64 bit version or 32 bit version. There is a 32 bit version of internet explorer 7 and 8 in vista you can found in the “program files x86” folder.
This folder you can see in a c: drive. It will work perfectly with flash plug-in. you can also download a adobe flash player uninstaller. You can download this official site of adobe player.
After downloading, run that in your computer, then , right-click on Internet Explorer icon of your Taskbar, select: Run as administrator and then visit to a official website of adobe flash player. Your problem will be solve.
