Adobe flash Plugin for Symbian phones free download
My symbian phone doesn't seem to play videos on YouTube. Does it require a plugin? Where can i download adobe flash plugin for symbian phones?
Unfortunately, Symbian doesn't have Flash plugins. In order for you to play videos on Youtube, you should visit the mobile version of the site, and your Real Player will be able to play Youtube videos, or you can use the Opera browser to play videos on Youtube because that browser has Flash support. You can download it at m.opera.com.
-Nelson
Hi Robinson Clark,
Yes there is an adobe plug-in that can be used to play YouTube videos on your symbian powered device. It is light weight and free to use. Download it from this link using your device. https://en.softonic.com/download/adobe-flash-lite/windows/post-download?ext=1
The software is called Adobe Flash Lite. It can access SWF data from internal or external memory card. You can play, pause, select previous and next like in any other player. It takes less than 1 MB of space.
