I am using Adobe Flash Professional CS for my iOS Game App and I have this error when I try to create or add some files. This error started to appear recently and I was hoping that it will solve by itself. Does anyone have any idea about this error ? Please help me to solve this…
Thank you experts !
Error creating file.
Id warning: CPU_SUBTYPE_ARM_ALL subtype is deprecated: C:\Adobe
CS6\Adobe Flash
CS6\air4-0_sdk_win_\lib\aot/lib/libNoDebugger1.arm-air.a(avmplusDebuggerStubs.cpp.0)
Adobe Flash professional cs error in iOS games app
If you use the Publish command in Adobe Flash Professional to create a file, the Publish command, by default, creates a Flash Pro SWF file and an HTML document that inserts your Adobe Flash Professional content in a web browser window. If an error happened while creating a file, check if you are using the latest version of Adobe Flash Player.
If not and you are still using an old version, visit the Adobe website and download the latest version. In case you have a problem downloading the file or the web installer doesn’t finishes the download, download the offline installer from Adobe Flash Player Latest Standalone. This downloads the installer directly from Macromedia website. Additionally, if you want to install Adobe Flash Player ActiveX, download the offline installer from Adobe Flash Player ActiveX Latest Standalone.
It is also a known issue for Adobe Flash Professional CS6 to throw an error when publishing an AIR for iOS app. An error is thrown when the path directing to the FLA file includes a double-byte character or high-ASCII character.
